Low power output, 24 pole 3 phase alternator | 11 comments (11 topical, editorial)
Re: Low power output, 24 pole 3 phase alternator w (3.00 / 0) (#5)
by Flux on Wed Aug 20th, 2008 at 02:27:15 PM MST
You only have a closed magnetic circuit on one side. Yes you do need to close the other side of the coils and when you do this then you may well find that your original steel backing is not thick enough. With a closed circuit each side iron in the region of 1/4" or more will be needed. You will need to laminate any fixed iron over the coils or spin a disc with the magnets to avoid eddy currents.
Yes delta will get you down to 21V at the same speed.
Re: Low power output, 24 pole 3 phase alternator w (3.00 / 0) (#6)
by rfirth (rfirth1@(remove this part)lsu.edu) on Wed Aug 20th, 2008 at 02:55:58 PM MST
Wow, thanks. That makes perfect sense. Now I know what to do.
One last thing - the laminate on the iron - is that any insulating material? Does the laminate work well, or is spinning the disk a better option? It seems to me that keeping that disk stationary makes the design simpler, if I didn't have to worry about eddy currents. I just don't understand how laminating the iron prevents eddy currents. I see you call it a "high grade laminated iron backing", and high grade usually means expensive.
Thank you for your time. I was disappointed before, but now I'm excited. This is going to work.
Robert Firth
Low power output, 24 pole 3 phase alternator | 11 comments (11 topical, 0 editorial)
