What I have been doing, Solar and Conservation | 25 comments (25 topical, editorial)
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#1)
by TomW on Fri Aug 22nd, 2008 at 10:40:53 AM MST
mixerman;
You don't need to solar preheat your incoming water. What I mean is simply setting the extra tank up in line with the cold to the water heater will let the water sitting in the tank between uses rise above the temp it comes from the well at.
Better if its directly heated by the sun but every degree you raise it before it gets to the heater is one degree you don't need to put into it energy wise.
Just a thought. I call this an "ambient air temperature preheater"
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#2)
by SparWeb (sparweb at ANTISPAM_hotmail_com) on Fri Aug 22nd, 2008 at 11:05:07 AM MST
...I call this an "ambient air temperature preheater"
Are you sure that's a benefit?  Aren't you bringing a whole bunch of cold water into the house to just suck heat from the air?  That air that was heated somehow by using energy.  Heat the air in the house more, to "pre-heat" the water.  I don't get it.  Sounds like a zero-sum game.
What would be really neat would be a system that lets you transfer heat from waste water (eg from the shower, or better yet, dishwasher) in that pre-heater tank.  Can't picture big economic benefit in a house, but maybe this could be (or already has been) done in a commercial building.
Steven Fahey
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#3)
by zap (bell47g5a at comcast dot net) on Fri Aug 22nd, 2008 at 11:39:22 AM MST
It's been done... and even talked about here.  I can't find the story but here's something for you.
http://www.eere.energy.gov/consumer/your_home/water_heating/index.cfm/mytopic=13040
zap
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#8)
by mixerman on Fri Aug 22nd, 2008 at 01:07:04 PM MST
Thanks for the link. The copper lines going to the kitchen area would cost to much,I dont think you would gain much. Consider this! The kitchen sink water is supplyed with a 1/2" line , that water then drains in to a 1 1/2" drain, then to a 4" drain , how much of that water is in actuall contact with the drain pipe?!
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#18)
by ghurd on Sat Aug 23rd, 2008 at 07:43:19 PM MST
It's here,
http://www.fieldlines.com/story/2007/12/13/172543/25
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#19)
by zap (bell47g5a at comcast dot net) on Sat Aug 23rd, 2008 at 09:30:52 PM MST
Thanks G... board search and google search didn't want to work for me.
zap
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#4)
by TomW on Fri Aug 22nd, 2008 at 12:44:32 PM MST
Uh, well, mine sat in the yard. Basements generally are unheated here anyway. My point, which you obviously missed, was the simplicity of just a tank of water with no outside plumbing, solar covers, boxes, etc.
Just ideas.
If I am now required to explain every minute detail of the down sides to advice I will just stop offering it. I will leave that to the academics sitting in their offices.
I did this for years on the north side of my house and it worked great with no direct sun on the tank. When I had 2 in series it would get the second tank pretty close to the same temp as the air. I probably lost some gain to radiation to the night sky, too, but it was a net gain. I suppose I should note, in order to avoid you explaining the obvious, I only did this while outdoor temperatures were above 55 or 60 F. We have no basement. Info is in my Diary someplace since I actually shared it here long ago.
And, yes, waste heat recovery sounds good but likely not trivial for the non plumbing oriented.
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#10)
by SparWeb (sparweb at ANTISPAM_hotmail_com) on Fri Aug 22nd, 2008 at 03:30:10 PM MST
Actually, Tom, I was trying to act like the nerdy academic sitting in an office.  I was even waving a thermodynamics textbook in the air for added effect.  Too bad you couldn't have seen it.
After posting I remembered that there's a building in Calgary that has a heat-exchange system on waste water.  Probably city-owned.  Just wanted to add the idea to the thread because it's always sounded interesting to me.
Steven Fahey
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#6)
by mixerman on Fri Aug 22nd, 2008 at 12:56:10 PM MST
I dont think I will find that much difference from street water temp and winter time house temp, maybe 10-15 degrees, guessing! Our basement is not heated on purpose. The room where the tank is located is alot warmer than anywhere else in the basement. In the Winter I could maybe direct heat from the ele dryer around the chilled tank. Just a idea!
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#9)
by ghurd on Fri Aug 22nd, 2008 at 01:12:26 PM MST
Often called a "Tempering Tank".
Depends on where you live?
We don't heat the house about 7 months a year.  3 months welcome any cooling.
If I could get the water from 55F to 72F, that is a gain.
My cheapie water heater is far less efficient than my furnace.  Much of the water temp increase would be caused by heat from the efficient furnace, instead of the cheap water heater.
That would mean a gain too... I think.
Here, the electric co gave a reduction in rates if an 80 gal tempering tank was installed before an electric water heater.
No idea if they still do.
That waste water thing is cool.  Someone did a study of a working unit in a USA duplex, and I figured DIY payback was like a couple months before copper went up.
I would have one if our shower was over a basement.  :-/
I often thought SOMETHING before the recovery part would increase the temp.
Maybe 50' of 3/4" CU.
Maybe 25' of 3/4 CU with 6" pieces of scrap #12 soldered to the sides as a heat sink (anti-heat sink?).
And maybe if that verticle do-hickey was insulated it would work better.
I see there are a buch of new replies since I started, but I'm leaving this as-is.
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#12)
by mixerman on Fri Aug 22nd, 2008 at 05:22:50 PM MST
I cant see where coils around the out side of a pipe momently coming in contact with heat will do it. This I think is better.
mixerman
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#14)
by DamonHD (d@hd.org) on Sat Aug 23rd, 2008 at 01:23:11 AM MST
The coils round the side of the pipe apparently do work because (if you've set things up correctly) when showering a thin film of water runs down the inside of the waste pipe transferring its heat very effectively and flow is not impeded.
A grey-water sump as you have shown will accumulate 'bath hair' and worse and breed exciting biofilms and worse IMHO!
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#20)
by BigBreaker on Mon Aug 25th, 2008 at 08:07:17 AM MST
I agree with Damon on grey-water.  It shouldn't stand for more than 24 hours and it should never go through regular (small) valves, tight curves, traps or diameter reducers.  The hassle of pulling out the hair will cause the project to be abandoned.  It will clog.
Perhaps a flapper valve and toilet hardware would work?
For grey water think big diameters and slow.
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#21)
by mixerman on Mon Aug 25th, 2008 at 08:42:15 AM MST
I think what is meant is a virtical drain pipe is coiled on its outside not in any direct contact with the heated gray water.
In my pictue you will see that the coils are in contact with the gray water, Im sure this would allow for some kind of build up! (soap scum, hair, cooties)the core of the tank would be self-contained though! Dont really know if the build up would really effect its effenecy or create some kind of hassard.
The plumbing would remain the same size in use in the system 1 1/2" traps should work fine , the existing drain traps have never cloged in 20 years. For a controled drain maybe a ele t-stat! I think some cas have them today.
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#22)
by BigBreaker on Tue Aug 26th, 2008 at 09:03:15 AM MST
I think the coils in the grey water tank will get some build up.  Also that tank will need to be totally drained daily to avoid having it go septic.  I would consider putting the coils on the outside of the tank rather than inside.
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#5)
by mixerman on Fri Aug 22nd, 2008 at 12:46:41 PM MST
I could probely do something like that to! I wouldent want to be bringing a tank from out in the yard to do seasonaly, I could do it both ways! Not that much plumbing involved. I dont have well water, I'll have to check and see what temp the city water is coming in at.
Originally my thoughts were just set it out in the Sun, drain lines an dont use it in Winter.
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#7)
by TomW on Fri Aug 22nd, 2008 at 12:57:17 PM MST
mixer;
I added a set of frostless faucets to the outside one Ted off before and one Ted off after a ball valve in my cold in to the heater. attach tank to those with top to the after faucet and the first faucet to the bottom [or dip tube] of the tank. That way, come freezing weather you just turn off the faucets, remove the lines, open the ball valve and you are back to "normal". When using the preheater you close the ball valve to force water to go through the preheater. My water heater is within a few inches of the north wall of the house and I bought good quality washing machine hose to go from the faucets to the tank.
You could easily do it both in and outside with some thought.
Good luck with it.
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#11)
by Norm (peppysue@suite224.net) on Fri Aug 22nd, 2008 at 03:34:28 PM MST
I thought of doing something like that when we
replaced my daughter's water heater....was going
to strip it down ....nice sheet metal covering too
....but then they don't make 'em like they used to...
insulation glued to the tank...and glued to the sheet metal
...so I said...forget that!
( :>) Norm
What I have been doing, Solar and Conservation | 25 comments (25 topical, 0 editorial)
