What I have been doing, Solar and Conservation | 25 comments (25 topical, 0 editorial)
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#13)
by Simen on Sat Aug 23rd, 2008 at 12:07:17 AM MST
(User Info) http://www.mwlmf.net
I've been playing around with something like graywater exchange lately, though only manually from my bathtub... ;)
I've made a small solarpanel with a size of 20sq. inch, which are connected to an old 30gal. heater tank. In a sunny day, it'll raise those 30 gal. of water from around 70f to 82f-86f. I'll make a diary of it here sometime... ;)
Point is; after a bath (with lukewarm water from my 30gal. solar-tank, supplied with hotwater from my ordinary heater.), the temperature of the bathwater would be around 96f-100f. At this point, my solar-tank would be empty, so i fill it slowly with tapwater through a 10ft 1/2" coppercoil submersed in the used bathwater. That raises the tapwater from 46f to around 75f. :)
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#15)
by Old F on Sat Aug 23rd, 2008 at 03:58:12 AM MST
If you can fix the leak in the old gas water heater you  can  strip out the burner an use the flue as a heat exchanger
 This is what I have been using  with my Out door wood stove  to heat my hot water
Here is a link to my wood stove saga
http://oldf.homestead.com/Woodmasterishere.html
An look in to using PEX tubing  for the long runs a lot cheaper than copper
Old F
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#16)
by mixerman on Sat Aug 23rd, 2008 at 06:33:38 PM MST
That is a good idea! I like your stove. Have you ever stripped one of those tanks with the hot wire?
I forgot about there being a center in that tank, that changes things!
thanks for the link.
mixerman
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#17)
by mixerman on Sat Aug 23rd, 2008 at 06:42:14 PM MST
Those are good results. Would like to read that dirary when you make it.
mixerman
