What I have been doing, Solar and Conservation | 25 comments (25 topical, 0 editorial)
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#20)
by BigBreaker on Mon Aug 25th, 2008 at 08:07:17 AM MST
I agree with Damon on grey-water.  It shouldn't stand for more than 24 hours and it should never go through regular (small) valves, tight curves, traps or diameter reducers.  The hassle of pulling out the hair will cause the project to be abandoned.  It will clog.
Perhaps a flapper valve and toilet hardware would work?
For grey water think big diameters and slow.
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#21)
by mixerman on Mon Aug 25th, 2008 at 08:42:15 AM MST
I think what is meant is a virtical drain pipe is coiled on its outside not in any direct contact with the heated gray water.
In my pictue you will see that the coils are in contact with the gray water, Im sure this would allow for some kind of build up! (soap scum, hair, cooties)the core of the tank would be self-contained though! Dont really know if the build up would really effect its effenecy or create some kind of hassard.
The plumbing would remain the same size in use in the system 1 1/2" traps should work fine , the existing drain traps have never cloged in 20 years. For a controled drain maybe a ele t-stat! I think some cas have them today.
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#22)
by BigBreaker on Tue Aug 26th, 2008 at 09:03:15 AM MST
I think the coils in the grey water tank will get some build up.  Also that tank will need to be totally drained daily to avoid having it go septic.  I would consider putting the coils on the outside of the tank rather than inside.
