What I have been doing, Solar and Conservation | 25 comments (25 topical, editorial)
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#4)
by TomW on Fri Aug 22nd, 2008 at 12:44:32 PM MST
Uh, well, mine sat in the yard. Basements generally are unheated here anyway. My point, which you obviously missed, was the simplicity of just a tank of water with no outside plumbing, solar covers, boxes, etc.
Just ideas.
If I am now required to explain every minute detail of the down sides to advice I will just stop offering it. I will leave that to the academics sitting in their offices.
I did this for years on the north side of my house and it worked great with no direct sun on the tank. When I had 2 in series it would get the second tank pretty close to the same temp as the air. I probably lost some gain to radiation to the night sky, too, but it was a net gain. I suppose I should note, in order to avoid you explaining the obvious, I only did this while outdoor temperatures were above 55 or 60 F. We have no basement. Info is in my Diary someplace since I actually shared it here long ago.
And, yes, waste heat recovery sounds good but likely not trivial for the non plumbing oriented.
Re: What I have been doing, Solar and Conservation (3.00 / 0) (#10)
by SparWeb (sparweb at ANTISPAM_hotmail_com) on Fri Aug 22nd, 2008 at 03:30:10 PM MST
Actually, Tom, I was trying to act like the nerdy academic sitting in an office.  I was even waving a thermodynamics textbook in the air for added effect.  Too bad you couldn't have seen it.
After posting I remembered that there's a building in Calgary that has a heat-exchange system on waste water.  Probably city-owned.  Just wanted to add the idea to the thread because it's always sounded interesting to me.
Steven Fahey
What I have been doing, Solar and Conservation | 25 comments (25 topical, 0 editorial)
