other use for wind energy | 12 comments (12 topical, editorial)
Re: other use for wind energy (3.00 / 0) (#5)
by kbaxter26 on Fri Aug 22nd, 2008 at 11:11:24 AM MST
I need help. I need to motor that will produce 10W @ 300rpm or less. I already have a VAWT design that is working very well, just can't seem to find a suitable "generator".
Re: other use for wind energy (3.00 / 0) (#6)
by SparWeb (sparweb at ANTISPAM_hotmail_com) on Fri Aug 22nd, 2008 at 11:14:38 AM MST
kbaxter:
You have posted your new topic at the end of an old topic.  The moderators may choose to delete this, but they will invite you to post the question in a new thread, too.
You should do a bit more reading on this site.  You will find info to help without needing to ask, and in the process learn much more than what a single question would bring.
Good luck.
Steven Fahey
Re: other use for wind energy (3.00 / 0) (#7)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Fri Aug 22nd, 2008 at 11:34:07 AM MST
On the Upper-Right-Hand side of the page, in the "Menu" Box is the link to "Submit Posting" please use that for creating New Questions.
W o o f -={(
Re: other use for wind energy (3.00 / 0) (#11)
by electrondady1 on Sun Aug 24th, 2008 at 10:38:55 AM MST
traditionaly big vertical axis mills were used to grind grain into flour
i watched a tv show were some guys did just that.
i wonder if it would be possible to grind electronic stuff like tv's and computors
into powder and separate the various substances according to there relative densities.
other use for wind energy | 12 comments (12 topical, 0 editorial)
