Fresh design idea of a VAWT onto my house | 26 comments (26 topical, 0 editorial)
Re: Fresh design idea of a VAWT onto my house (3.00 / 0) (#4)
by vawtman (vawtman(at)charter(dot)net) on Fri Aug 22nd, 2008 at 12:10:03 PM MST
Hi Akos
 I don't think it's a good idea.
 Flappy blades will be too slow unless you build a monster that could tip your house over.If anything happens your insurance co. will not cover it.If you tell them they will more and likely drop you.
 Anybody can make a vawt spin.Harnessing the power takes time and study.
 Just my opinion though.
Mark
Re: Fresh design idea of a VAWT onto my house (3.00 / 0) (#7)
by Akos on Fri Aug 22nd, 2008 at 12:59:41 PM MST
Ok, I am thinking on having around 1000 W if possible.
My idea is that I am ok to cover all my house's area (viewing from above) to make a slowly, but powerfully spinning VAWT.
I do not want to connect to household power, only heating in winter (and maybe cooling in summer). We pay too much on heating due to my wife's temperature needs. What I think is that I would like to make a very simple machine with minimum part number kept in mind in order to make it paying back quickly. I can make the VAWT seen in the video from around 30 parts (including washers for nuts). No need for battery, no need for inverter, only a simple (and cheap) water heater to be added to the heating system.
Anyway, what do you think why this kind of turbine system have not come up to light more intensly? Does it have some inherent problem with it?
Re: Fresh design idea of a VAWT onto my house (3.00 / 0) (#8)
by wdyasq on Fri Aug 22nd, 2008 at 01:39:31 PM MST
"Anyway, what do you think why this kind of turbine system have not come up to light more intensly? Does it have some inherent problem with it?"
Yes, it doesn't work .....
Re: Fresh design idea of a VAWT onto my house (3.00 / 0) (#9)
by electrondady1 on Fri Aug 22nd, 2008 at 02:00:01 PM MST
 since your proposed mill rotates at less that the speed of the wind
it is technically a wind mill not a turbine.
it's just an opinion but i think big verticals are just now coming into there own.
of course in the right location, you can get a much bigger return from your investment from a horizontal prop type devise.
just the swept area required is daunting to most builders.
if you want to build to the scale you have described you will need to structurally alter your house .
not everyone is willing or able to do that.
lets say your house is 1,000 sq.ft.
perhaps 31 ft. per side .
if you had a flat roof and could build a mill ten ft high it would sweep 310 sq ft.
that's a nice number!
but your not going to convince anyone it's a "colonial,spanish or Victorian  style"
that's ok too,
 it is the twenty-first century.
Re: Fresh design idea of a VAWT onto my house (3.00 / 0) (#14)
by Akos on Fri Aug 22nd, 2008 at 03:15:14 PM MST
I would be ready to make a 2 meter (6,5 foot) high blade on a 4 meter (13 foot) axis. That would give me about 8 m2. But I would take into acount only one side of the mill because exactly what I am trying to do is to minimise the drag on the other side, so it even would be better to magically skip those area. Those squaremeters should not count into the swept area, should they.
Re: Fresh design idea of a VAWT onto my house (3.00 / 0) (#10)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Fri Aug 22nd, 2008 at 02:04:20 PM MST
Looks like the mechanisms that rotate the blades will steal all of your power before you can use it.
W o o f -={(
Re: Fresh design idea of a VAWT onto my house (3.00 / 0) (#12)
by vawtman (vawtman(at)charter(dot)net) on Fri Aug 22nd, 2008 at 02:15:58 PM MST
I agree Woof
Re: Fresh design idea of a VAWT onto my house (3.00 / 0) (#15)
by Akos on Fri Aug 22nd, 2008 at 03:18:03 PM MST
No, no, this is very small power needed there. While off-wind, the balanced blades can be moved almost effortlessly. It will be about right timing. (Just like pre-ignition on 4 stroke engines...)
Re: Fresh design idea of a VAWT onto my house (3.00 / 0) (#16)
by vawtman (vawtman(at)charter(dot)net) on Fri Aug 22nd, 2008 at 03:28:31 PM MST
The problem is a wind turbine is not driven by a engine.Go ahead and build it and see.
