Mini wind farm | 9 comments (9 topical, editorial)
Re: Mini wind farm (3.00 / 0) (#4)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Fri Aug 22nd, 2008 at 02:15:05 PM MST
Well ,  Yes you are correct
only one of us has been able to do it
W o o f -={(
Re: Mini wind farm (3.00 / 0) (#5)
by thefinis (thefinis@hotmail.com) on Sat Aug 23rd, 2008 at 07:48:20 PM MST
Not quite right either as there have been at least two other folks with working/producing vawts but both of them were based on Ed's design. Gizmo had one up and making power not sure if it is still up and the one that (?Wayne) built that was portable (if you had a pickup truck). His was taken out in a storm by a tree limb. He did rebuild it but I think he made it a 2 wing instead of a 3 wing. Hmmmmm do not remember hearing anything about it after the conversion.
Vawts can fill some niches and if you want something to watch spin and make a little power why not a vawt? The thing is most vawts tend to be yard art that can make some power and tend to be more art than anything else. One big drawback is how material intensive a vawt is when compared to a hawt of the same output. The extra weight means they are usually placed on a low tower or at ground level. This just compounds the power output problem due to lower wind speeds. Will a vawt work at ground level? Yes! Will it work well? No! Is it worth doing even if it ends up with just watching them spin? All the neighbors and the wife think so. Sometimes I'm not sure.
Finis
Texas born and bred
Re: Mini wind farm (3.00 / 0) (#6)
by electrondady1 on Sun Aug 24th, 2008 at 07:09:02 AM MST
i can't remember the final result as far as power output goes but
cmebrew did some nice work with this unit.
http://www.fieldlines.com/story/2007/10/5/1192/20143
Re: Mini wind farm (3.00 / 0) (#9)
by luckeydog (bryan@coloradowindpower.com) on Sat Aug 30th, 2008 at 11:58:45 PM MST
(User Info) http://www.coloradowindpower.com
well here is a 10 kw  VAWT
wind gens are much funner to watch than solar panels. Broomfield,Colorado
Mini wind farm | 9 comments (9 topical, 0 editorial)
