My Parabolic Trough Water Heater | 27 comments (27 topical, editorial)
Re: My Parabolic Trough Water Heater (3.00 / 0) (#15)
by fcfcfc on Sun Sep 7th, 2008 at 07:03:26 PM MST
Hi:
Looks nice... I think you would have better results from a lot of different perspectives though, if you would insulate the pipe rather than the whole unit. What you need is a piece of borosilicate glass one inch bigger in diameter than the receiver pipe. This will give you a 1/2" "dead" air space for insulation. It will solve you expansion issues with the mirrors and the whole exo-structure thermal stress problem. The tube will get hotter and get hotter faster as well. Just make sure your reflector material is up to the "weather" challenge....
A good material for the exposed reflector is this:
http://www.reflectechsolar.com/index.html
.....Bill
Re: My Parabolic Trough Water Heater (3.00 / 0) (#16)
by brianc4 on Sat Sep 13th, 2008 at 04:05:53 PM MST
Bill,
   Thanks for the link to the reflective material it may be just the stuff I am looking for!
   I have looked at the borosilicate glass tube designs on the net and they are neat compact & efficient but also very expensive. I would love to use the design but can't afford it at this time so I was playing with other designs I can afford.
Brian Clark
Re: My Parabolic Trough Water Heater (3.00 / 0) (#18)
by fcfcfc on Sun Sep 14th, 2008 at 07:04:23 AM MST
I may be able to help you there... What is the diameter of the receiver pipe you are using..??..
.....Bill
Re: My Parabolic Trough Water Heater (3.00 / 0) (#19)
by brianc4 on Mon Sep 15th, 2008 at 09:58:14 AM MST
Bill,
   For The prototype I used a 2" schedule 40 aluminum pipe 2-3/8" outside diameter.
   I can change pipe size if needed.
Brian Clark
Re: My Parabolic Trough Water Heater (3.00 / 0) (#20)
by fcfcfc on Mon Sep 15th, 2008 at 02:40:00 PM MST
Hi: I might be able to get you 2 lengths of 70mm borosilicate glass from broken single wall evac tubes, around 5' long each. I would just have to get them cut off smooth. That is around 2.75 inches outside. The cost to cut the glass at the glass shop should not be more than around $20 plus the shipping and packaging to send it to you where ever you are, if interested.....
My Parabolic Trough Water Heater | 27 comments (27 topical, 0 editorial)
