My Parabolic Trough Water Heater | 27 comments (27 topical, editorial)
Re: My Parabolic Trough Water Heater (3.00 / 0) (#2)
by oztules (oztules__at__bigpond.com) on Sat Aug 23rd, 2008 at 03:48:32 PM MST
Interesting design, do you think that you should insulate the stainless mirror from behind to keep the ambient inside temperature up (the plastic did it for you here I think).
Neat example of heating up above the passive ones.
.........oztules
Re: My Parabolic Trough Water Heater (3.00 / 0) (#5)
by brianc4 on Mon Aug 25th, 2008 at 03:39:56 PM MST
oztules,
   On the prototype in this post I used 3-1/2" fiberglass batt insulation between the back of the mirror & the plastic back on the trough.
   For the final unit I may have a local contractor spray in polyisolene insulation.
   Also considering double pane glass on the front for a dead air gap & better insulation.
   I think that the parabolic style solar water heater can work well even in a cold climate if the collector tube is protected from ambient air.
Any thoughts on insulation or glass for front cover would be appreciated.
Brian
My Parabolic Trough Water Heater | 27 comments (27 topical, 0 editorial)
