My Parabolic Trough Water Heater | 27 comments (27 topical, 0 editorial)
Re: My Parabolic Trough Water Heater (3.00 / 0) (#3)
by phil b (philb7369at-no-more spam-yahoo.com) on Sun Aug 24th, 2008 at 07:38:30 AM MST
Nice work!
I can see a definate advantage with your parabolic heater. Flat panels continue to heat up when not in use, and are difficult to shade.You can simply turn the collector out of the sun.
Thanks for sharing!
Re: My Parabolic Trough Water Heater (3.00 / 0) (#6)
by brianc4 on Mon Aug 25th, 2008 at 03:49:46 PM MST
Phil b,
  On the final unit I want to put 4 troughs on a tracking unit tied to a thermostat & a plc. Which like you said can be rotated out of the sun if temperature gets to hot.
  I also think with a little planning the tracking unit can be made to rotate out of harms way in a storm to avoid hail damage.
   The tracker can also be made to rotate the troughs down at night to avoid snow accumulation in the winter.
   Lots of posabilities!  Still in the R&D stage & having lots of fun!
Brian Clark
