Hi Edaddy
Next step?
I will put the 1/2in plywood mags over the real ones and set the outer band.Then design the brackets for it.You can see part of it in the pic sitting on the table.
The outer band will have no mags but rotate with the wheel(rotor).
Then take the whole thing apart and give it the final finish of Devthane.(a high gloss ureathane finish for corrosive environs.
Then test coil and umbrella.
