MPPT - 55.8V array to 12V battery bank | 21 comments (21 topical, editorial)
Re: MPPT - 55.8V array to 12V battery bank (3.00 / 0) (#14)
by Walt Er on Mon Aug 25th, 2008 at 02:05:41 PM MST
OK before anyone beats me to it, the voltage is too high for the charge controller (at least the one I was looking at).  Voc at freezing temperatures would be too high.  Back to the drawing board. -Walt
Re: MPPT - 55.8V array to 12V battery bank (3.00 / 0) (#16)
by ghurd on Mon Aug 25th, 2008 at 08:37:54 PM MST
A lot of people like the Outback MX-60.  Certainly worth a serious look.
The #14 wire has me wondering.
Any less wire losses in MPPT makes more power to the battery.
Going up to #12 would be cheap.  Even #10 is not much more money.
I use #12 for a 50W panel.
When it is finished you will understand what you have, and how it works!
Re: MPPT - 55.8V array to 12V battery bank (3.00 / 0) (#18)
by Walt Er on Tue Aug 26th, 2008 at 08:17:15 AM MST
FYI,
It was the Outback I was looking at.  They have a tool that calculates Voc at various temperatures for various panels to see if the MX60/FM60/FM80 can handle it.
The link is:  http://www.outbackpower.com/forum/viewtopic.php?f=7&t=2900
Then click on "String Sizing Tool".
The record low temp where I'll be installing the system is -25 degrees F, which made the Voc too high for these controllers.
I have found some 180W and 195W panels with lower voltages, so I can string three together in series and still fall well within the limits of the controllers even at very cold temps.
-Walt
MPPT - 55.8V array to 12V battery bank | 21 comments (21 topical, 0 editorial)
