MPPT - 55.8V array to 12V battery bank | 21 comments (21 topical, 0 editorial)
Re: MPPT - 55.8V array to 12V battery bank (3.00 / 0) (#5)
by electronbaby (roy<at>windsine.org) on Sun Aug 24th, 2008 at 06:27:37 PM MST
Im not sure about that formula, but it appears to me that if you want 90Ah/day with 3 hours insolation, then you should be looking at a larger PV array, MPPT or not.
Have Fun!! RoyR KB2UHF
Re: MPPT - 55.8V array to 12V battery bank (3.00 / 0) (#6)
by Walt Er on Sun Aug 24th, 2008 at 09:12:46 PM MST
Alright, let me get this straight.
Starting with rated Watts - say 4 125W panels, 17.3V, 7.23A wired in series...
If everything was perfectly efficient and real life equaled rated life...
Using an MPPT controller I should get Vmodule/Vbattery*Imodule amps into my 12-volt battery bank.  69.2V/13.5V*7.23A = 37A.  I used 13.5V as sort of an average between 12 and 14.7.
Now, I've got to factor in the inefficiences:
Real life panel Wattage - 80% of rated
Controller efficiency - 93%
So my 37A becomes 37*.8*.93 = 27.5A.
That's about 20% higher than I'd get if the four panels were in parallel, assuming the same 80% "real life" reduction, so that jives with some of the earlier comments.
Are those reasonable percentages, and are there other inefficiencies I haven't considered?
Thanks for lending your experience to this newbie - Walt
