Wrong Motor | 56 comments (56 topical, editorial)
Re: Wrong Motor (3.00 / 0) (#1)
by Norm (peppysue@suite224.net) on Mon Aug 25th, 2008 at 06:53:32 AM MST
Need Much More Data ......
How big are your blades? What rpm does the motor
spin to make 130 volts?
We have no way of knowing 5000 rpm?
Seem to spin at a good rate?
M'Gosh ...I have some pinwheels out in my yard
that are spinning at a good rate..
(not being sarcastic just giving you an example)
If you have a motor that will give you about 3 or
4 volts cranking it by hand at 60 rpm then you
might have the right motor.......
( :>) Norm
( :>) Norm
Re: Wrong Motor (3.00 / 0) (#2)
by Norm (peppysue@suite224.net) on Mon Aug 25th, 2008 at 06:56:54 AM MST
  3 or 4 open volts, that is
( :>) Norm
Re: Wrong Motor (3.00 / 0) (#4)
by adaml on Mon Aug 25th, 2008 at 07:16:49 AM MST
That is 3volts with no load, just connected to multimeter.
Re: Wrong Motor (3.00 / 0) (#3)
by adaml on Mon Aug 25th, 2008 at 07:04:10 AM MST
Thanks Norm,
Apologies new to all this but should have provided better info.
Blades are 36", 3 of made of 6" pvc piping I had lying about, mounted on an 8" aluminium hub.
I reckon that in today's wind (which is the strongest I have tested in yet) I am getting about 200 - 300 rpm max.  I do not reckon this is enough even though the blades are spinning to fast to visually keep up with sometimes.
When I initially got the motor I did rig it up, a spin with my fingers was enough to make a 12v car light bulb glow.  Spinning it up on my drill at maximum rev's turned out about 80v.
I am trying to build this as a prototype for a friend who wants to set it up on a remote piece of land.
The tower is approx 12"
My apologies again for the original scant infromation.
Many thanks for you help.
Adam.
