Re: Wrong Motor (3.00 / 0) (#19)
by adaml on Tue Aug 26th, 2008 at 09:05:50 AM MST
Thanks ghurd, please could you put that in layman's (or idiots) terms!!!!!  I am guessing that means I need to cut some off the blades near the hub??  I should have posted in the newbie section, I now realise!!
Re: Wrong Motor (3.00 / 0) (#21)
by ghurd on Tue Aug 26th, 2008 at 09:54:40 AM MST
About half as wide near the hub.
Quick guess: measuring around the curve near the hub should be about 2.5" or 2- 5/8".
The far blade in the pic looks strange at the hub.
The near and highest blade looks like the tip may be twisted backwards, and that will get worse as pressure from the wind increases, slowing the blades down.  The tip should be angled the same direction as the root (hub area).
The diameter will have to be smaller too.  Maybe 42" is what I would try, for no other reason than a gut feeling.
The hub looks OK, but I'm not too picky about that.
Don't expect much until the leaves fall, and the location still won't be very good.
I don't think all hope is lost.  I am sort of surprized it made 3V like it is.
Re: Wrong Motor (3.00 / 0) (#22)
by adaml on Tue Aug 26th, 2008 at 10:13:13 AM MST
Thanks ghurd, so I need to shave some of the blade width off near the hub and reduce blade length/overall diameter?  All I did to make these blades, as a first attempt, was to 1/4 6" pipe, use masking tape as a stencil and cut along that, hadn't done much other tampering with the design!!  I didn't know what to expect when first hooked up to multimeter but when whipping round got just over 3v unloaded.  I suppose I am looking for maximum speed for the area, as you say not the ideal location.
Supposed to be working but fascinating info on here, thanks to all, and for all the continued help.
Re: Wrong Motor (3.00 / 0) (#23)
by ghurd on Tue Aug 26th, 2008 at 10:53:21 AM MST
Yes, shorter, narrower blades.
And it wasn't whipping around.  It was crawling by our collective standards.
Wait until you see it with better blades!
Scared the poo out of me the first few times.
CmeBREW has a pic that will give you an idea of how it should end up.
His are tweaked for his purpose, but notice the root area where it meets the hub.
His have a curve after that, which isn't needed.
Also notice the tip of the far blade, and its angle.
Best pic I could recall.
http://www.otherpower.com/images/scimages/3274/leesonpvcblades2.jpg
Re: Wrong Motor (3.00 / 0) (#24)
by adaml on Tue Aug 26th, 2008 at 11:32:00 AM MST
Thanks very much ghurd and LOL, obviously still snails pace then, enough to split my nose open when I walked into it trying to get the cat in!!
I have another rough cut set of blades 24" in length each.  I will try to narrow these off and attach them and see what happens, would you reckon that is an acceptable length or do you suggest shortening to 21"?  Thanks for the continued help.
Re: Wrong Motor (3.00 / 0) (#27)
by CmeBREW (smke833f@hotmail.com) on Tue Aug 26th, 2008 at 02:04:09 PM MST
This is in response to the PVC blades link that Ghurd showed.  I hope scoop puts it in the right place-- sometimes it goes to the very bottom of the thread.
That link to the pvc blades were my first version. I trimmed them down thinner to make them go faster here:
However, the diameter of these blades is 6ft. 10 inches.
The 12v cut-in for the big DC motor I used for this prop was only 130rpm--- which is Much, MUCH slower than his 620rpm (12v) cut-in dc motor.
Even though these blades are quite fast (not as fast as wood though) , they would be nowhere near fast enough for that motor the poster has.
I think he needs to get a better dc motor with a lower 12v cut-in.
Also , I think the cogging is significant with his motor and very difficult to start up with a 4' diameter prop even with 5 thin pvc blades.
Re: Wrong Motor (3.00 / 0) (#28)
by ghurd on Tue Aug 26th, 2008 at 03:09:09 PM MST
I do know what you mean, but the perspective in the photo you posted makes them look like spaggetti!
I tried to show him the end view.  His end view of the root looks like nearly 90 degrees.  Your photo shows the end view of a decent PVC blade very well.
The motor could be better.
I am trying to get something from what is available, before he gives up.
Re: Wrong Motor (3.00 / 0) (#29)
by CmeBREW (smke833f@hotmail.com) on Tue Aug 26th, 2008 at 05:24:10 PM MST
Ghurd-
Yeah, it is difficult to see the perspectives clearly with photos.  You are right, the one you showed shows the angles better for a perpective. I just thought I would say that by making them even thinner (less wide) it did clearly get more speed which is what he needs a lot of.
I could not see his photo of his mill anywhere.  How are all of you seeing his photo??
I even went to his 'files' to try to find it, but no photo!
No one ever said if his blades are pvc or wood?? I suppose pvc.
I also hope he don't get discouraged. I remember the frustration of only reaching 10 volts (so close, yet SOO far away!) in a fairly big wind with motors similar to that one.
Maybe Flux's high speed blade design can get over that cogging well enough and  make the extra speed needed.  Worth a try.
Re: Wrong Motor (3.00 / 0) (#31)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Wed Aug 27th, 2008 at 05:46:18 AM MST
Here are his pictures . . .
http://www.otherpower.com/images/scimages/11306/
W o o f -={(
Re: Wrong Motor (3.00 / 0) (#30)
by adaml on Wed Aug 27th, 2008 at 02:57:28 AM MST
Hi Ghurd, many, many thanks again, and to you all, would be easy to get dispondent at this stage!  I have tried to post two new pics, following norms instructions.  One of the blades mounted on a test hub and another of a smaller blade I was tinkering with last night.  Your continued input would be very much appreciated.  Also have been looking at a Ametek 30vdc on Ebay but getting expensive!!
Re: Wrong Motor (3.00 / 0) (#32)
by ghurd on Wed Aug 27th, 2008 at 06:57:26 AM MST
The new blade looks a lot better.
The blades on the test hub are far too wide at the root.  Looking at them straight from the front, part of the back of the blade is visable.  That is simply way too wide to work much at all.
Another look at the 1st photo makes me wonder how close the blades match.
The better they match, the faster it will turn with a load.
The 80V with the drill turning it...  What is the name plate RPM of the drill?
Re: Wrong Motor (3.00 / 0) (#33)
by adaml on Wed Aug 27th, 2008 at 08:27:49 AM MST
Thanks Ghurd and for the continued encouragement.  I will have to look at the drill rpm when I get home tonight.  Probably quite high as its a decent Bosch I brought to punch hole through the wall of the house!
I had offered the blades up to each other and weighed each as best I could.  I know the match was not 100% but was reasonably happy with it.  I had not balanced yet either.
Re: Wrong Motor (3.00 / 0) (#34)
by adaml on Thu Aug 28th, 2008 at 03:29:18 AM MST
Ghurd, I have followed your advice and shortened and narrowed the blades, have posted pic of them up.  I would be most grateful for your thoughts.  They certainly look a lot better to me!
Re: Wrong Motor (3.00 / 0) (#35)
by ghurd on Thu Aug 28th, 2008 at 07:29:13 AM MST
Much better!
Still not a great motor, and the blades are probably not a good match to the motor (PVC blades are somewhat forgiving), but the chances of it working just went up a lot.
I am quite confident they will reach charging voltage.
I would expect charging to start at about 0.1875 x drill RPMs.
The 0.1875 is from the drill test (15V charging voltage / 80V tested).
But you never can tell if the motor knows the math!  Many of mine do not.
I hope you learn something from it, and have fun.  The next one is easier.
Great emphasis needs placed on the current site being VERY bad.
It will need to be in a spot with nothing in front or behind.  Or higher.
I get nothing as soon as the trees bud in spring.  Your trees look more dense than mine.
Re: Wrong Motor (3.00 / 0) (#37)
by adaml on Thu Aug 28th, 2008 at 09:42:53 AM MST
Hi Ghurd,  Thanks so much for your continued support.  I have ordered a totally different motor, my calculations should give approx 12v at 180rpm in 5-10mph winds, has been shipped so getting excited! Found an old post on here where someone else had brought the same motor as this and gave up, someone else posted they were no good....you live and learn and is all fun!  This turbine is to go on top of a hill on an island in the Adriatic so hopefully lots of sea breezes.  For mine I will go a lot higher to clear as much wind interference as possible.
Will also try to reshape my old larger blades for a bit more experimentation.  The small ones went last night in a breeze with a push to get them going so I think I am also suffering with this "no good" motor from cogging, if that is the correct term?!  Thanks again Ghurd, wish I had found this forum long ago!
Re: Wrong Motor (3.00 / 0) (#36)
by TomW on Thu Aug 28th, 2008 at 08:05:28 AM MST
adam;
I realize you are in "testing mode" but I have to mention that dangling cable is very likely to get caught in the prop if you don't secure it from flopping around as a big loop. Had it happen myself on a test stand it made a mess and ripped the cable and brushes right out of the Ametek I was testing. I didn't see it happen but the postmortem indicated it had yawed hard and the loop opened and did not follow fast enough and the blade hooked in the loop and the rest was simply physics.
You are coming along nicely. Getting rid of that curl at the root should help it speed wise.
Re: Wrong Motor (3.00 / 0) (#38)
by adaml on Thu Aug 28th, 2008 at 09:45:34 AM MST
Thanks Tom, will get rid of that loop tonight, that was laziness on my part, no excuses!!
Re: Wrong Motor (3.00 / 0) (#43)
by adaml on Mon Sep 1st, 2008 at 07:08:18 AM MST
Thanks again all.  Have adapted blade and speed is a lot better, never thought it would go that fast!!  Can I ask what is probably a really fundamental and beginners question about load and its definition.  I am getting about 24v plus "unloaded" which I define as nothing bar multimeter connected.  The thing I have noted is that with the motor connected to even just the three core wire down the tower that there is far more physical resistance coming from the motor.  Connected to a bulb for example then this is even greater.  This is what I understand to be "load".  Am I correct in this line of thinking?  Many thanks and apologies for sounding like and idiot!!
Re: Wrong Motor (3.00 / 0) (#44)
by ghurd on Mon Sep 1st, 2008 at 08:54:56 AM MST
I knew it would work.  :-)
There should be no extra drag with just more wire.  Check for one wire touching another.
The bulb is a load, but it is almost a short as far as the windmill is concerned.  Bulbs are not much good for testing a windmill.
When charging a battery, no current will flow until the windmill voltage is higher than the battery voltage + diode voltage.  No current flow means unloaded.
There should be no current flowing before about 7MPH wind, or it will "stall" trying to make power that is not available in the amount of wind.
Things will improve when the battery is connected.
You understand you need a blocking diode?
Re: Wrong Motor (3.00 / 0) (#45)
by adaml on Mon Sep 1st, 2008 at 09:02:52 AM MST
Thank again Ghurd, you have been great support and encouragement.  Will check the wires tonight when get home but don't think any touching.  Have taken the three from the motor, connected to 7 meters 3 core down the inside of the tower then to rectifier. Connected to a battery would be a load also?  I tested just by connecting my multimeter to the output with nothing else connected (pic on file), so unloaded.   Have ordered a blocking diode and brought an inline fuse to go between the mill and batteries.  Have acquired five new car batteries, understand they are not ideal but think they will do for a start.
Also see there is a book out, will wait for pay day and pre-order!!
Thanks again. Will keep you posted. If ever there is anything I can do in return.......
Re: Wrong Motor (3.00 / 0) (#46)
by TomW on Mon Sep 1st, 2008 at 09:17:03 AM MST
adam;
Careful, now. If you go praising Ghurd too much, between that all the income from his controller he will not be able to get in or out of his shop with his swollen head.
Seriously, tho, he is a great contributor here along with many others, of course.
Luckily his newfound fame and fortune have not significantly affected his humility [YET]!
Re: Wrong Motor (3.00 / 0) (#47)
by adaml on Mon Sep 1st, 2008 at 09:23:01 AM MST
LOL Tom!!
Re: Wrong Motor (3.00 / 0) (#49)
by ghurd on Tue Sep 2nd, 2008 at 07:53:18 AM MST
I still fit through doorways...
My ears only rub a little!  :-)
Re: Wrong Motor (3.00 / 0) (#50)
by TomW on Tue Sep 2nd, 2008 at 10:17:58 AM MST
M
A
N
T
h
i
s
t
h
r
e
a
d
h
a
s
g
o
t
t
e
n
n
a
r
r
o
w
T
Re: Wrong Motor (3.00 / 0) (#48)
by adaml on Mon Sep 1st, 2008 at 02:02:08 PM MST
HI Guys and Ghurd, just to let you know took mill to friends farm and set up there, 20mph wind avg, highest reading on multimeter just over 70v unloaded so reckon heading in right direction!!  Thanks again all for the help and inspiration.
