Re: Wrong Motor (3.00 / 0) (#29)
by CmeBREW (smke833f@hotmail.com) on Tue Aug 26th, 2008 at 05:24:10 PM MST
Ghurd-
Yeah, it is difficult to see the perspectives clearly with photos.  You are right, the one you showed shows the angles better for a perpective. I just thought I would say that by making them even thinner (less wide) it did clearly get more speed which is what he needs a lot of.
I could not see his photo of his mill anywhere.  How are all of you seeing his photo??
I even went to his 'files' to try to find it, but no photo!
No one ever said if his blades are pvc or wood?? I suppose pvc.
I also hope he don't get discouraged. I remember the frustration of only reaching 10 volts (so close, yet SOO far away!) in a fairly big wind with motors similar to that one.
Maybe Flux's high speed blade design can get over that cogging well enough and  make the extra speed needed.  Worth a try.
Re: Wrong Motor (3.00 / 0) (#31)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Wed Aug 27th, 2008 at 05:46:18 AM MST
Here are his pictures . . .
http://www.otherpower.com/images/scimages/11306/
W o o f -={(
