The blades on the test hub are far too wide at the root. Looking at them straight from the front, part of the back of the blade is visable. That is simply way too wide to work much at all.
Another look at the 1st photo makes me wonder how close the blades match. The better they match, the faster it will turn with a load.
The 80V with the drill turning it... What is the name plate RPM of the drill? G-[ Parent ]
I am quite confident they will reach charging voltage. I would expect charging to start at about 0.1875 x drill RPMs. The 0.1875 is from the drill test (15V charging voltage / 80V tested). But you never can tell if the motor knows the math! Many of mine do not.
I hope you learn something from it, and have fun. The next one is easier.
Great emphasis needs placed on the current site being VERY bad. It will need to be in a spot with nothing in front or behind. Or higher. I get nothing as soon as the trees bud in spring. Your trees look more dense than mine. G- [ Parent ]
I realize you are in "testing mode" but I have to mention that dangling cable is very likely to get caught in the prop if you don't secure it from flopping around as a big loop. Had it happen myself on a test stand it made a mess and ripped the cable and brushes right out of the Ametek I was testing. I didn't see it happen but the postmortem indicated it had yawed hard and the loop opened and did not follow fast enough and the blade hooked in the loop and the rest was simply physics.
You are coming along nicely. Getting rid of that curl at the root should help it speed wise.
There should be no extra drag with just more wire. Check for one wire touching another.
The bulb is a load, but it is almost a short as far as the windmill is concerned. Bulbs are not much good for testing a windmill.
When charging a battery, no current will flow until the windmill voltage is higher than the battery voltage + diode voltage. No current flow means unloaded.
There should be no current flowing before about 7MPH wind, or it will "stall" trying to make power that is not available in the amount of wind. Things will improve when the battery is connected.
You understand you need a blocking diode? G-[ Parent ]
Careful, now. If you go praising Ghurd too much, between that all the income from his controller he will not be able to get in or out of his shop with his swollen head.
Seriously, tho, he is a great contributor here along with many others, of course.
Luckily his newfound fame and fortune have not significantly affected his humility [YET]!
T h i s
t h r e a d
h a s
g o t t e n
n a r r o w
T
