I am quite confident they will reach charging voltage. I would expect charging to start at about 0.1875 x drill RPMs. The 0.1875 is from the drill test (15V charging voltage / 80V tested). But you never can tell if the motor knows the math! Many of mine do not.
I hope you learn something from it, and have fun. The next one is easier.
Great emphasis needs placed on the current site being VERY bad. It will need to be in a spot with nothing in front or behind. Or higher. I get nothing as soon as the trees bud in spring. Your trees look more dense than mine. G- [ Parent ]
