There should be no extra drag with just more wire. Check for one wire touching another.
The bulb is a load, but it is almost a short as far as the windmill is concerned. Bulbs are not much good for testing a windmill.
When charging a battery, no current will flow until the windmill voltage is higher than the battery voltage + diode voltage. No current flow means unloaded.
There should be no current flowing before about 7MPH wind, or it will "stall" trying to make power that is not available in the amount of wind. Things will improve when the battery is connected.
You understand you need a blocking diode? G-[ Parent ]
Careful, now. If you go praising Ghurd too much, between that all the income from his controller he will not be able to get in or out of his shop with his swollen head.
Seriously, tho, he is a great contributor here along with many others, of course.
Luckily his newfound fame and fortune have not significantly affected his humility [YET]!
T h i s
t h r e a d
h a s
g o t t e n
n a r r o w
T
