Putting Another Generator in the Air | 5 comments (5 topical, 0 editorial)
Re: Putting Another Generator in the Air (3.00 / 0) (#3)
by TomW on Thu Aug 28th, 2008 at 07:51:55 AM MST
"Poor Boy" windmills make power before the others,
and you understand them down to the last turn in the last coil.  :-)
Yes, great point[s], G;
Another important but often missed part of DIY is when push comes to shove the DIY turbine is likely to be back up and flying after damage from a catastrophe than a factory unit that has specialized components that require either a tech or the factory to install. The home builder understands that certain parts can be rebuilt in the garage with what is onhand if needed.
It is hard to duplicate the feeling you get from installing your home built turbine by installing something you simply bought.
Re: Putting Another Generator in the Air (3.00 / 0) (#5)
by luv2weld (luv2weld at hughes dot net) on Sun Sep 7th, 2008 at 05:56:15 PM MST
Tom,
You and Glen are right. It does start a lot sooner than the factory
made rigs.
And getting it back in the air is just like you said. In the next couple
of Days, I'll be posting some crash pictures to prove what you're saying.
Ralph
