Alternator design for big LENZ | 10 comments (10 topical, editorial)
Re: Alternator design for big LENZ (3.00 / 0) (#9)
by filipeandremail on Sat Aug 30th, 2008 at 11:08:42 AM MST
hi,
I have 8-12 mph winds in the summer but in the winter 20-25.
12 volts output would be fine
Re: Alternator design for big LENZ (3.00 / 0) (#10)
by Todd a on Sun Aug 31st, 2008 at 10:11:39 AM MST
drag type VAWT are very limitted on the speed.  They can not move faster than the wind... resulting in the low TSR.  A lift type VAWT can have a higher RPM as it can go faster than the wind (like a VAWT), but has a poor start-up speed.  A combination is best really for the DIY.  It also sounds like those numbers are for HAWT and likely will not give you as accurate of numbers.  VAWT have a larger surface area than what the the area covered for a HAWT has. and depending on the design, you can get a power stroke out of 25 to 75% of the stroke depending on design.
It just can not take into acount design differences like...
http://www.youtube.com/watch?v=Uj2c4NreTSY&feature=related
http://www.youtube.com/watch?v=dl6m4emdeBI
http://www.youtube.com/watch?v=q7ffNWkefyY&feature=related
http://www.youtube.com/watch?v=8FbiPI1iYSk&feature=related
http://www.youtube.com/watch?v=CZ1KN0fKqyA&feature=related
http://www.youtube.com/watch?v=RPN_oZf1DSc&feature=related
http://www.youtube.com/watch?v=UdoKEYNfoVE&feature=related
http://www.youtube.com/watch?v=q9flSPAdOLk&feature=related
http://www.youtube.com/watch?v=CkIX3_O8sWg&feature=related
http://www.youtube.com/watch?v=ZXYUBNpa4Hg
These are a wide range of designs, ranging from about half the size of yours up to probably 2 times.  Not all give ratings, but some say from 500w to 5kw.  Now the Lenz type do not seem to be the best of the ones I show above, but you might be able to get a 1Kw if you can gear up your generator as the speed of 91mph at 20mph wind is actually probably a bit high.  For VAWT they lower the diameter the higher the RPM for drag types.
Alternator design for big LENZ | 10 comments (10 topical, 0 editorial)
