2008 summer progress. | 10 comments (10 topical, editorial)
Re: 2008 summer progress. (3.00 / 0) (#1)
by tecker on Fri Aug 29th, 2008 at 08:00:58 AM MST
 A few have used doughnut magnets .It's very cool to get power from used stuff like that . It's hard to get the wire off clean and have the insulation good . I've been able to use polyurethane with some success . You can increase your  power by adding a neo in the hole the same polarity as the doughnut face . An oposite pole is present in the hole that messes with the peak charge times . Those look like between 12 and 19 mm either will do with some super glue and epoxie .
Re: 2008 summer progress. (3.00 / 0) (#2)
by tecker on Fri Aug 29th, 2008 at 08:03:28 AM MST
I see you can add another magnet rotor as you get more materials that will increase the ouput also .
Re: 2008 summer progress. (3.00 / 0) (#3)
by gotwind2 (ben[at]gotwind.org) on Fri Aug 29th, 2008 at 12:57:24 PM MST
(User Info) http://www.gotwind.org/index.htm
Great work margusten.
Cosidering the re-use of scrap materials, maybe you could use computer hard drive Neodymium magnets for your next attempt, as MickS did in Australia, story below.
http://www.fieldlines.com/story/2006/10/8/112046/572
Ben.
www.gotwind.org
Re: 2008 summer progress. (3.00 / 0) (#4)
by margusten (margusten.ee@mail.ee) on Fri Aug 29th, 2008 at 02:18:04 PM MST
(User Info) http://www.geocities.com/ResearchTriangle/Thinktank/1780
I have more than 100 used computer hard discs waiting for disassemling and making next generator. It means more trouble than disassembling 12 microwawe owens.
Read my older diary about single phase machine using wery old computer scasi drive magnets. Definately Neodynamium magnets are much better, I noticed it when I was not able to separate this double rotor machine without tools.
This microwawe maget machine is double rotor machine too. Only pictures here taken from early stadium.
I was able to separate second magnet rotor from machine by two hands. Of course stator thichness was same, same mold used.
I had same idea to make weak microwawe magnets stronger by adding additional neodynamium magnets to ferrite magnet hole.
But I read from this forum that Neodynamium magnet can kill Ferrite magnet soon.
And I was afraid and let holes empty.
Is it true?
I hope to add some more pictures soon.
BR,
Margus
Re: 2008 summer progress. (3.00 / 0) (#6)
by tecker on Fri Aug 29th, 2008 at 04:28:05 PM MST
It won't be a problem you have to surround the magnet for a weakening you reallydon't need much just hide that pole in the middle maybe a harddrive mag or a piece of one on a 12mm ferrite button or cut washers.
2008 summer progress. | 10 comments (10 topical, 0 editorial)
