Is this idea cracked? | 8 comments (8 topical, editorial)
Re: Is this idea cracked? (3.00 / 0) (#2)
by quailman on Sun Aug 3rd, 2008 at 04:31:28 PM MST
Thank you for time.So if I understand this correctly if Imake a new stator for the second turbine I would use more turns and larger wire to bring down cutin speed.would this also call for a larger blade?
Re: Is this idea cracked? (3.00 / 0) (#3)
by Flux on Sun Aug 3rd, 2008 at 04:42:26 PM MST
No not even you could be so lucky, life doesn't quite work that way.
Re: Is this idea cracked? (3.00 / 0) (#5)
by scoraigwind (magnet@scoraigwind.co.uk) on Sun Aug 3rd, 2008 at 11:47:15 PM MST
(User Info) http://www.scoraigwind.co.uk
"if I make a new stator for the second turbine I would use more turns and larger wire to bring down cutin speed.would this also call for a larger blade?"
If you use more turns and larger wire then the coils will not fit the stator.  To fit the stator with more turns per coil, you will need to use thinner wire.  The longer, thinner wire will have much higher resistance.  So your maximum output will be reduced to about half.  Using the 10 foot blade you can produce more power in low winds.  But if you want high power in high winds, then the seven foot blade will actually deliver higher power without burning out, because it will have a lower internal resistance with its thicker wire.
Personally I tend to go for a larger diameter with a lower max power because that results in steadier power output, but most people prefer the idea of a high maximum power even if it is rarely actually seen due to the small diameter of the blades.
I hope you understand the trade-off.
Best wishes,
Hugh
Is this idea cracked? | 8 comments (8 topical, 0 editorial)
