Stater electrical testing | 11 comments (11 topical, 0 editorial)
Re: Stater electrical testing (3.00 / 0) (#5)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Mon Aug 4th, 2008 at 04:11:33 AM MST
If you are measuring AC voltage that is not a clean Sine wave in the 50/60hz range, then your meter may be giving you some inaccurate results. Low priced Digital multimeters are designed to measure AC from clean grid sources.
W o o f -={(
Re: Stater electrical testing (3.00 / 0) (#6)
by Jason Wilkinson (jason_wl48@hotmail.com) on Mon Aug 4th, 2008 at 09:07:59 AM MST
I always wondered why? wooferhound, my vector inverter shows only 95v ac while the grid 110  yet the inverter run all lights bright, power drill and saw works fine yet only 95v ac.
 Jason
Re: Stater electrical testing (3.00 / 0) (#7)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Mon Aug 4th, 2008 at 01:07:52 PM MST
The frequency is correct to measure when it's coming from an inverter.
But, the difference is that the inverter is putting out Square Waves, and the grid is giving you Sine Waves, that is what is giving you the difference in your AC voltage readings.
W o o f -={(
Re: Stater electrical testing (3.00 / 0) (#8)
by Jason Wilkinson (jason_wl48@hotmail.com) on Mon Aug 4th, 2008 at 02:56:49 PM MST
Thanks for that  woofer
