Doc Wattson (net?) Meter | 3 comments (3 topical, editorial)
Re: Doc Wattson (net?) Meter (3.00 / 0) (#1)
by pvale (pvale at pvale dot com) on Sun Aug 3rd, 2008 at 07:12:11 PM MST
Sorry, no the "Doc Wattsun" or "Watts Up" meters are not bi-directional. I have an old E-meter that does this. The E-Meter is sold as the Xantrex "Link 10" meter now. These meters keep track of AH into and out of the batteries. I do use a Watts Up meter on my solar input to see what the total generated AH and Watt/Hrs were generated. Since my small 12V loads are 24/7, some of my solar input goes directly to the loads without any net charge to the batteries. The E-meter lets me see the large picture from my batteries viewpoint, and the Watts Up lets me see the total power generated by the solar array. I have several other DMM's that I use from time to time in various parts of the system. Even the little $12 Harbor Freight DMM's will directly measure up to 10A DC. I have a 10mv/A shunt connected directly in line with my solar panels, and I'll clip the little HF meter set on 200mv DC across it to directly read the solar input, especially if I'm using the Watt's Up meter for something else at the time. You can't beat the bang-for-the buck of those little red HF meters. I won't feel too bad if I accidently blow one. Better that than one of my Fluke meters. Good luck, the Watts Up meter is good for reading a load, but the Link 10/E-meter is a much better system meter.
Re: Doc Wattson (net?) Meter (3.00 / 0) (#2)
by valterra on Sun Aug 3rd, 2008 at 09:03:07 PM MST
Make that a $2.99 HF meter - I have 5.   lol.   :-)
For anyone interested - they're on sale again right now.
Thanks for the tip.  I guess I can't look to it for that.  The Good Doctor then would keep track of how much energy I've created then.
As for the HF Meters - My wind and solar both run THROUGH their own meter, so I can measure the current of each input individually.  With 3A wind and 2A solar, the +/- 50A gauge is overkill.   But for TOTAL loads versus charge, especially when "cheating" with a grid-powered charger, the big analog meter does move.
Re: Doc Wattson (net?) Meter (3.00 / 0) (#3)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Mon Aug 4th, 2008 at 07:59:13 AM MST
You are correct , they are not bi-directional.
BUT they can be run two together, with one backwards of the other.
They can also be left in place for charging . It doesn't bother them at all.
When we switched out the SLA's for NiCd packs in the e-tike, we had to go to using two of these due to the on-board unit being set for SLAs.
Doc Wattson (net?) Meter | 3 comments (3 topical, 0 editorial)
