VAWT land | 25 comments (25 topical, editorial)
Re: VAWT land (3.00 / 0) (#10)
by Norm (peppysue@suite224.net) on Sun Aug 31st, 2008 at 07:43:58 AM MST
I've tried 3 blades on a small scale (plastic
cups) 2 tiered, 2 blades per tier, offset 90
degrees from the other tier seems to work better
for me.
( :>) Norm
Re: VAWT land (3.00 / 0) (#11)
by tecker on Sun Aug 31st, 2008 at 08:48:49 AM MST
The jurys's still out on 90 second tier offset it depends on how the air enters the inner vortex if the second tier is blocked say with a plate between its effective but if the air goes from one tier to the other then the pressure exchange between the two interfears .
Re: VAWT land (3.00 / 0) (#13)
by windstuffnow (elenz(at)windstuffnow(dot)com) on Sun Aug 31st, 2008 at 11:19:52 AM MST
The ones I've tested I found the torque is that of 1 tier for the entire machine.  What it does is offset the torque pulse from 180 degrees to 90 degrees.  You have lower torque but a more continuous torque.
I built a 4 tier unit with the blades offset by only 22.5 degrees, very similar to the "twisted" or "helix" savonius.  This actually seemed to remove the torque pulse but still only carried the torque of one tier or slightly above.
Overall I never achieved much more than 20% efficiency with any of the units I built.  They provide a very good torque at low rpm and would be well suited for pumping water, running an air compressor and such but for electric they present a number of challenges.  It can be done...
Have Fun! Windstuff Ed
VAWT land | 25 comments (25 topical, 0 editorial)
