vinyl ester low temperature rating | 4 comments (4 topical, editorial)
Re: vinyl ester low temperature rating (3.00 / 0) (#2)
by DanG on Sun Aug 31st, 2008 at 07:09:07 AM MST
Adding a filler like talc, ATH or microspheres (or all three) will toughen up the resin at the coldest extremes. Also adding some chopped fine glass or kevlar strands might help if the copper shrinkage exceeds the resins' contractions or the uneven expansion from coil heating.
Super-cold will affect bearing adjustment and lubrication - your local snowmobile crowd may have good insight on trailer hubs at those obscene temperatures!
Re: vinyl ester low temperature rating (3.00 / 0) (#3)
by hiker (hiker.wild[at]yahoo[dot]com) on Mon Sep 1st, 2008 at 07:40:02 PM MST
im in anch...coldest ive been in was  -70 north slope..
what neck of the woods are you in?..............
WILD IN ALASKA
Re: vinyl ester low temperature rating (3.00 / 0) (#4)
by oregon wind on Tue Sep 9th, 2008 at 11:04:33 PM MST
The wind turbine will be sent to Wasilla.
vinyl ester low temperature rating | 4 comments (4 topical, 0 editorial)
