Rewind | 12 comments (12 topical, editorial)
Re: Rewind (3.00 / 0) (#5)
by oztules (oztules__at__bigpond.com) on Mon Aug 4th, 2008 at 03:08:04 PM MST
ULR,
Seedler was using a auto transformer to get up to the higher volts before to feed a grid connect inverter. So his output was already less current and more voltage than his original windings.
http://www.fieldlines.com/story/2008/8/1/141124/1643
Flux has indicated "Whatever the cause, the failure you have has all the symptoms of a faulty stator, it is a rewind and you can now change the turns and wire size to replace the nuisance of a transformer and get it running as originally intended. Don't use Chinese bearings in the rebuild either."
Seedler, yes turns/volt gave you the 240v, and the same turns/volt will dictate your new winding number.
.........oztules
Re: Rewind (3.00 / 0) (#6)
by oztules (oztules__at__bigpond.com) on Mon Aug 4th, 2008 at 03:09:39 PM MST
Crap.... ULR sorry, you seem to have resolved the problem while I was writing the above reply
.........oztules
Rewind | 12 comments (12 topical, 0 editorial)
