Wood Blades vs. PVC Blades | 13 comments (13 topical, editorial)
Re: Wood Blades vs. PVC Blades (3.00 / 0) (#9)
by domwild (domwild at hotmail dot com) on Mon Aug 4th, 2008 at 08:29:44 PM MST
Wooden blades will definitely outperform the PVC kind. My PVC blades seem to stall and never overspeed. The stall noise is a loud whosshing noise. I will try to build a mill without furling because of it. The beauty of PVC is that the blades can be shaped much more quickly. The problem is the inside curvature, which leads to bi- or triplane style wing profiles. Low speed!
Problems:
  1. Jerry suggested an aluminium sandwich setup at the root to stop the blade braking off there. That means two alu pieces at both sides of the root to distribute the load.
  2. PVC becomes brittle due to UV. Have bought a primer, which sticks to tiles, PVC, etc. and that can be used to be the base for later reflective paint, arctic white or silver.
  3. Suggestion is to tilt the prop axle a few degrees up and away from the horizontal, so there is a larger separation of the wing tips from the mast, when the blade is at the lowest point. The blade will bend towards the mast and hit it otherwise.
Re: Wood Blades vs. PVC Blades (3.00 / 0) (#10)
by elt on Tue Aug 5th, 2008 at 05:02:51 AM MST
> The problem is the inside curvature, which leads [...] Low speed!
Gives me an idea - I found a piece of 8" PVC 30" long and am going to make blades this week; I'll try wrapping them in saran wrap (don't have monokote) to flatten the front and see what happens.
- Ed.
Re: Wood Blades vs. PVC Blades (3.00 / 0) (#11)
by valterra on Tue Aug 5th, 2008 at 08:20:15 AM MST
"My PVC blades seem to stall and never overspeed."
That's another great point.  Even my wood blades, which ARE poorly made by any official standards (read my post about the mistakes I made)...  the one thing I can say about these blades, with the not-so-good airfoil shape, is that you can watch them accelerate.  You can "see" the lift in action.  I did NOT see that with my PVC / Barrel blades.
Wood Blades vs. PVC Blades | 13 comments (13 topical, 0 editorial)
