Treadmill Motor PVC Blades | 49 comments (49 topical, editorial)
Re: Treadmill Motor PVC Blades (3.00 / 0) (#11)
by roadranger (Road Ranger at G Mail dot com) on Tue Aug 5th, 2008 at 07:35:27 PM MST
You can - of course - change the mounting hole positions lengthwise along the blade to match your hub and adjust the length at the root to give you exactly 24" tip to center of hub. The positioning of the holes at 3/4" in from the trailing edge is critical to get the right angles along the blade. It is also very important to sharpen the blade only on the inside of the pipe (toward the wind) to get the proper angle of the blade.
Treadmill Motor PVC Blades | 49 comments (49 topical, 0 editorial)
