I guess my question is this- Should I try making a mark 2 inches in from the root on the leading edge and draw a line on the existing blades to shorten them to 24inches? If so- How wide should the tips be?
Or... Should I start over with 4inch pvc and make them shorter than 24inches? Would I just cut the 4inch in half and use the halfs to make quarters? If so-where would I draw the line to narrow them?
It all comes down to this...The wind speed here averages 9mph. I need something that would be useful in slower winds and still be able to charge a battery or two- Can I do this or is this a waste of time with this motor?
I also have a woodshop in my basement and have not ruled out making wooden blades out of laminated hardwood...what are your thoughts on all of this???
Thanks for all the great info!
Bob[ Parent ]
Oh, and most folks say wooden blades are way better (2x ?) than pvc - but I don't know of any comparison using a properly calculated PVC rotor. A properly carved blade will always outperform any "pipe blade" but I don't know by how much?
Cutting a PVC blade that "looks good enough" as the how-tos show and expecting optimum results seems a bit silly to me. If you are interested in seeing the most annoying presentation of the proper design of a pvc blade you are likely ever to see check this out: http://www.youtube.com/watch?v=BawUfbDDvtA I calculated mine in a similar fashion but i think I compensated for a couple issues he overlooked. For instance, how you sharpen the trailing edge has a large effect on the blade angle, especially out near the tip which can be going 160mph in a 20mph wind![ Parent ]
That video turned me off!
In your opinion, should I scrap this idea(Thats all I really wanted to know) I would like to try something with it and was hoping for a more doable solution with the 4inch or cutting the existing blades shorter and narrower.. Could I try that and see what happens.. if you had this---what would you try to at least get it to spin in a 10mph wind.
Thanks for your opinion
Where did you get your motor? The eBay 130V "windmill" motors are all 6750rpm which is completely unuseable![ Parent ]
