Treadmill Motor PVC Blades | 49 comments (49 topical, editorial)
Re: Treadmill Motor PVC Blades (3.00 / 0) (#16)
by roadranger (Road Ranger at G Mail dot com) on Wed Aug 6th, 2008 at 10:37:34 AM MST
Motors have losses so as a motor the rpms will be less than some theoretical and as a generator the rpms would have to be more than the theoretical. My motor has been documented as running no-load at 2000rpm at 100V but needing 2800rpm to generate 100V.
Re: Treadmill Motor PVC Blades (3.00 / 0) (#19)
by packman1234 on Wed Aug 6th, 2008 at 06:44:14 PM MST
(User Info) packman1234
I just tried cutting the existing pipe to  24" long  1  5/16 at tip and 4" at the root with the same bolt holes and it still wont move!  BUMMER!!
Is the 4" the way to go or is it cogging too much to do anything??
Help!!
Bob
Treadmill Motor PVC Blades | 49 comments (49 topical, 0 editorial)
