Treadmill Motor PVC Blades | 49 comments (49 topical, 0 editorial)
Re: Treadmill Motor PVC Blades (3.00 / 0) (#18)
by packman1234 on Wed Aug 6th, 2008 at 04:59:47 PM MST
(User Info) packman1234
Roadranger
That video turned me off!
In your opinion, should I scrap this idea(Thats all I really wanted to know)
I would like to try something with it and was hoping for a more doable solution with the 4inch or cutting the existing blades shorter and narrower.. Could I try that and see what happens..
if you had this---what would you try to at least get it to spin in a 10mph wind.
Thanks for your opinion
Bob
Re: Treadmill Motor PVC Blades (3.00 / 0) (#21)
by roadranger (Road Ranger at G Mail dot com) on Wed Aug 6th, 2008 at 07:56:44 PM MST
It really should at least spin as-is in a 10 mph wind. I'd first try to balance it better using a piece of shafting and a couple ball bearings. Some have taken their motor apart and just used the armature with it's bearings to balance with but you'd have to convince yourself that you know how to get it apart and together without messing up the brushes. Then with this motor I'd try the 3' version of my rotor first. Then if you are up to carving wooden blades I'd search around a bit for the measurments and go for a 3' rotor designed for a TSR of 8. I don't think a 4' rotor can ever be fast enough to work well under 15mph.
Where did you get your motor? The eBay 130V "windmill" motors are all 6750rpm which is completely unuseable!
Re: Treadmill Motor PVC Blades (3.00 / 0) (#23)
by packman1234 on Wed Aug 6th, 2008 at 08:06:40 PM MST
I got the motor out of a Sears treadmill that my sister had.
I took it apart a few times to replace the two bracket mounting screws and see what it was all about..No biggie playing with this-Very strong magnet and sucks the case end in super hard and tight!
Bob
Re: Treadmill Motor PVC Blades (3.00 / 0) (#25)
by roadranger (Road Ranger at G Mail dot com) on Wed Aug 6th, 2008 at 08:16:06 PM MST
Just for reference this is the "originally spec'd" motor:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=220008972818
Re: Treadmill Motor PVC Blades (3.00 / 0) (#28)
by packman1234 on Wed Aug 6th, 2008 at 08:39:05 PM MST
Thats not even close to the one I have,,,specs are but hub is bigger and not threaded.
Mine is 2.5hp at 130v at 3200 rpm
