Treadmill Motor PVC Blades | 49 comments (49 topical, editorial)
Re: Treadmill Motor PVC Blades (3.00 / 0) (#7)
by packman1234 on Tue Aug 5th, 2008 at 06:29:53 PM MST
(User Info) packman1234
Dont get me all confused!!
Is it ok to have this unit spin clockwise? The new design of my blades will determine this..The voltage readings I get make no difference when reversing leads and spinning it clockwise and counterclockwise.
Bob
Re: Treadmill Motor PVC Blades (3.00 / 0) (#8)
by roadranger (Road Ranger at G Mail dot com) on Tue Aug 5th, 2008 at 07:00:45 PM MST
The "original" motor has a flywheel/fan on the shaft that is screwed on with a left handed thread. If you mount a "clockwise" rotor on it it will unscrew and fall off when you "load" the motor. I don't know how your motor is?
Re: Treadmill Motor PVC Blades (3.00 / 0) (#10)
by TomW on Tue Aug 5th, 2008 at 07:23:21 PM MST
Bob;
I am speaking from purely an electrical standpoint.
I do not know the motor and another poster notes their could be mechanical issues with reversing it.
Not sure what you mean by "The voltage readings I get make no difference when reversing leads and spinning it clockwise and counterclockwise."? If the polarity of the voltage does not change with reversing directions then something else is going on. It is not easy to get a handle on what a poster understands.
Sorry I even jumped in.
Sorry to confuse you. Really.
Treadmill Motor PVC Blades | 49 comments (49 topical, 0 editorial)
