Temperature control of small 12V fan | 32 comments (32 topical, editorial)
Re: Temperature control of small 12V fan (3.00 / 0) (#10)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Tue Aug 5th, 2008 at 03:48:31 PM MST
I was thinking that the battery will hold the voltage down good enough ?
It is a dump load on a wind turbine isn't it, even equalizing voltage shouldn't hurt it.
W o o f -={(
Re: Temperature control of small 12V fan (3.00 / 0) (#12)
by tecker on Tue Aug 5th, 2008 at 04:14:19 PM MST
I can't tell if he's useing a dumper or not but the 7812 is cheap enough . Of coarse the fan needs to be under an amp. The charge voltage will ride up anyhow with a charge .
Temperature control of small 12V fan | 32 comments (32 topical, 0 editorial)
