Temperature control of small 12V fan | 32 comments (32 topical, editorial)
Re: Temperature control of small 12V fan (3.00 / 0) (#6)
by CmeBREW (smke833f@hotmail.com) on Tue Aug 5th, 2008 at 01:13:03 PM MST
Maybe you could screw some more aluminum pieces to the side to improve the heat disipation better?? (or get more rectifiers)
Or, sometimes you can find a 12v cooling fan that has brushes and just hook it up with a diode and the cooling fan only comes on when the mill generates power.
The majority of little cooling fans are brushless and use a transistor which will not work with direct hook up like that since it blows the transistor.
Temperature control of small 12V fan | 32 comments (32 topical, 0 editorial)
