Pivot for tilt up three-sided tower | 15 comments (15 topical, 0 editorial)
Re: Pivot for tilt up three-sided tower (3.00 / 0) (#11)
by SparWeb (sparweb at ANTISPAM_hotmail_com) on Mon Aug 11th, 2008 at 12:22:34 AM MST
Looked at your comment about the math, and maybe it looks okay to you, but you've brushed over a major load condition without analyzing it.
While lifting the tower, it is extremely vulnerable.  Your winch/tractor may jerk the line - that could triple the load in an instant.  A guy wire might get snagged or come up short - that could also double the load.  Where's the gin pole?  You don't show it, so I bet you haven't factored in the loads IT imposes on the same hinge point.  There are even more things to consider than that, but those are the biggies, and I think I've made my point already.
You also missed a crucial load consideration for backyard truss towers: when your brother-in-law says "so how solid is that thing" and climbs on to "test it".
Steven Fahey
Re: Pivot for tilt up three-sided tower (3.00 / 0) (#14)
by elt on Tue Aug 12th, 2008 at 06:48:34 AM MST
Thank you Steven, I do appreciate a check list of what must be accounted for; however, the most compelling point to me is this: I think my base is stronger than the manufacturer's tilt up base. I can look at jin poles, jerk and climbing forces but if they aren't show stoppers with their base then they won't be with mine.
The math concentrating on the base strength is to convince myself that that is so, not to make little of the overall problem.
Thanks again,
 - Ed.
