Pivot for tilt up three-sided tower | 15 comments (15 topical, editorial)
Re: Pivot for tilt up three-sided tower (3.00 / 0) (#13)
by SparWeb (sparweb at ANTISPAM_hotmail_com) on Mon Aug 11th, 2008 at 09:14:36 AM MST
Your way of looking at the narrow question of strength of materials won't get you into too much trouble, but your back-of-the-envelope calcs won't get you far when you have to deal with the larger structure, and there are many questions to answer.
Structural engineering is interesting enough that I enjoy it, but it's not everyone's cup of tea.  If you want to go further, then you really must get a hold of an engineer (or at least a student) and maybe pick up an engineering textbook or two (the student would also be a good source for that).
There's a 2.5" diameter pipe rotating inside a 3" diameter pipe at the base of my tower.  Bolted into the concrete through an angle.  Welded together.  Easy to make.  Could pull a dumptruck out of quicksand.  You did the same amount of work, but it won't get a VW out of a ditch.
Reducing size and weight is valuable in aircraft.  Please reassure me that you don't want your tower to fly away!
Steven Fahey
Pivot for tilt up three-sided tower | 15 comments (15 topical, 0 editorial)
