Ethanol Boosting | 17 comments (17 topical, editorial)
Re: Ethanol Boosting (3.00 / 0) (#14)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Thu Aug 14th, 2008 at 08:51:26 AM MST
It is strange that they seem to keep "reinventing" these old ideas every so many years apart ;-)
Even a decade or so ago there was a gentleman that was able to produce, with his own money, much higher MPGs by merely using add on parts for better air control around the car, mostly in the ground effects region, much like F1 cars did back in the 70s when the Elf Torrelle 6-wheel car came out.
With new "tools" comes new insights. Will be interesting to see how far they push the limits this time.
Re: Ethanol Boosting (3.00 / 0) (#15)
by electrondady1 on Fri Aug 15th, 2008 at 06:45:40 AM MST
it's just my opinion, but i think their "flogging a dead horse"
if you lift the hood on a modern vehicle you can no longer see the engine.
system ,on system ,on system,hidden beneath showy air plenums
home repair, and maintenance next to impossible.
making a devise ever more complex is not good engineering .
Ethanol Boosting | 17 comments (17 topical, 0 editorial)
