Ethanol Boosting | 17 comments (17 topical, 0 editorial)
Re: Ethanol Boosting (3.00 / 0) (#8)
by Jeff (ruralmcguyver at yahoo dot com) on Sat Aug 9th, 2008 at 03:15:59 PM MST
Just a note for a few that haven't heard. This is a "somewhat good thing" for passenger vehicles. E85 or other alchohol type additives are not doing too good on small engines such as lawn mowers & weed-eaters. In fact, if those small engines are not modified to run on this type of fuel, they're doing a huge amount of damage!
The system talked about in the link though, IS a good thing for passenger vehicles, so it's worth your time to look into.
Don't forget though, auto manufacturers have long-made their policy of only making additions or modifications that eventually make them money! I was involved in a project in the early 80's designing and building an engine that eliminated the valve train. It used a cam/valve that was a rotating cylinder replacing the valves. It eliminated the conversion of rotating motion to reciprocal motion as in "cam to valves". It worked fantastic! It eliminated a lot of lost HP due to change of motion, less moving parts and less moving mass. Also the system could be designed to operate similar to a turbocharged or supercharged engine. The result was a Chevy 305 engine, producing 400+ HP and still getting close to 30mpg. The other major result was GM buying the patent rights, and NEVER appearing on the market! What really got my co-worker and I mad was this was the prototype, and we had plans on starting the drag-racing version! The same 305 engine with a 600+HP output! Well, it wasn't our design entirely. We just worked out the details and did the machining/assembly work. So...another major improvement in auto/engine technology held back by the major money-makers due to who would benefit from it the most!
Sorry about getting into the "rant" mode, but I think of this every time I see a new marketing push on improved auto engine efficiency.
Rural McG
Re: Rotary "valve/port-in-cam" (3.00 / 0) (#9)
by spinningmagnets (velmis1450bc(at)aol(dot)com) on Sat Aug 9th, 2008 at 09:50:22 PM MST
http://www.coatesengine.com/
They claim since it runs cooler than conventional exhaust valves, it can use 11:1 compression ratio with low-octane gasoline. Clearly they can smoothly spin to a very high RPM.
Re: Ethanol Boosting (3.00 / 0) (#11)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Mon Aug 11th, 2008 at 07:42:49 AM MST
Rural McG;
 It would be nice to "see" those plans. The patent rights should be close to being out. Most patents have to be renewed every 10 years.
