Inverter Ground making ADSL connection drop | 16 comments (16 topical, editorial)
Re: Inverter Ground making ADSL connection drop (3.00 / 0) (#12)
by dnix71 (yahoo.com 'dnix71') on Thu Aug 7th, 2008 at 07:57:37 PM MST
I don't know where I could get copper clad rod here, but there is a type of galvanized rod used locally that doesn't rust and is long and hard enough to hammer into rocky soil. It looks almost stainless, but I don't think it is. I've used pieces of it to weld on as handles for dock plates, and it didn't rust afterward.
Re: Inverter Ground making ADSL connection drop (3.00 / 0) (#13)
by dnix71 (yahoo.com 'dnix71') on Thu Aug 7th, 2008 at 08:11:43 PM MST
They look like this. If your really want copper ground, then hammer in rebar a little at a time and pull it out. When you get the depth you want, then hammer copper rod in the hole you made and water it in for good measure.
Re: Inverter Ground making ADSL connection drop (3.00 / 0) (#14)
by acapulco (thatskankystuff{at}hotmail) on Fri Aug 8th, 2008 at 12:22:47 AM MST
ok,
  phone guy rang instead of coming out, to be expected on a friday arv!
  He sounded bewildered when I attempted to explain. But then he said something like I need a "twisted cable pair" running from phone outlet to modem.
 However I drove a galv star picket in a few feet and grounded the inverter to that and it seems to at least improved the situation.
Now the ADSL only drops when I power up AUSTAR sat TV but then it comes good after a couple of minutes.
I can live with that....
especially seemin' it's friday arv and nearly drinkin' time ;p
cheers,
Ian..
SE QLD AUSTRALIA.*OFF-GRID*.RE:2x4xT105@24v./450Ah@24v IN:240w.PV,backup:Genset/charger24v@10amp cont. OUT:Mod.Sine Inverters: 1500w/4500w/2000w & 350w.
Inverter Ground making ADSL connection drop | 16 comments (16 topical, 0 editorial)
