Thanks for your reply :)
Yeh we are still contemplating the PMDC motor and are maybe thinking about building PMA's to fit around the 100mm shaft if we don't find a suitable motor.
We have two different ideas on running the LED's to create a glow effect within the sculpture. One will require more led's than the other and we have still not tested how well each method works. But from some simple calculations we can estimate the power needed from 100 led's and work from there.
We will be connecting 25 parallel connections of 4 LED's in series. This way we can run them at 12V and around 50mA per connection depending on the colour of LED. So all up we will have 1.25A @ 12V = 15W.
If we could get a gearless motor that had a low RPM rating with a voltage of 24V+ do you think it could work? The average windspeed in the location these sculptures are being installed is 22Km/h.
The prop is 500mm and the shaft is 100mm.
Another idea was to build some sort of PMA to run straight from the shaft.
Any thoughts would be much appreciated.
And thanks again for your quick reply
Regards
Brent
