Need help determining my amph hours | 5 comments (5 topical, editorial)
Re: Need help determining my amph hours (3.00 / 0) (#1)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Fri Aug 8th, 2008 at 01:36:13 PM MST
If the two strings are of equal ratings, then they add up.
I don't think I would discount the total amount to 60% though. For charging reason, the system need to know to total amount.
So you are correct in thinking that the total amount would be 750.
Hope this helps;
Re: Need help determining my amph hours (3.00 / 0) (#2)
by shaniac on Fri Aug 8th, 2008 at 02:32:17 PM MST
Thanks so much, here is what the manual says about reducing the amp hours by a percentage. Your thoughts please.
(snip)
Choosing battery capacity: The "battery capacity" means the number of amp -hours that your battery system holds when
it is full. A value of battery capacity should usually be selected that is equal or lower than the actual capacity. It's
recommended that you use a conservative (low) value for the TriMetric--50-75% of their factory rated value--
considering that the stated capacity numbers for batteries tend to be optimistic. They are also usually measured at 77
degrees F, and capacity will decrease somewhat at lower temperatures. Furthermore, they are rated from when they are
completely and utterly charged, which probably won't happen often in a real system.
(un-snip)
Re: Need help determining my amph hours (3.00 / 0) (#4)
by bob g on Sat Aug 9th, 2008 at 09:40:07 AM MST
that final comment really bothers me
"Furthermore, they are rated from when they are
completely and utterly charged, which probably won't happen often in a real system."
if you cannot provide for a "complete and utterly charged"
you have no business with batteries, unless you expect to get dramatically less lifespan out of them.
in my opinion of course :)
bob g
Re: Need help determining my amph hours (3.00 / 0) (#5)
by TomW on Sat Aug 9th, 2008 at 09:45:31 AM MST
bob;
Darned good point.
You gotta cook em occasionally and keep them full as much as possible or suffer drastic reduction in capacity and lifespan.
Need help determining my amph hours | 5 comments (5 topical, 0 editorial)
