How to decide on a system voltage? | 14 comments (14 topical, editorial)
Re: How to decide on a system voltage? (3.00 / 0) (#11)
by RandomJoe on Sun Aug 10th, 2008 at 10:38:05 AM MST
I found out about the fridge this morning!  I guess I'd been lucky with the other motor-driven things I've tried to run off generator or inverter.  Up til now I'd only had one thing (9000 BTU mini-split A/C) that I couldn't get to start on the generator.  Interestingly, the 9000 BTU portable A/C unit does start and run just fine on it.  (The first time I had it on generator, I thought just the blower was running, kept waiting for the compressor to kick in.  Then realized it was blowing cold air!)
But I tried running the fridge with a 300W (600W surge) Samlex pure-sine inverter, and no joy!  The inverter made some noise, I saw a 100W draw, but nothing from the fridge then a few seconds later the inverter tripped.  My Kill-A-Watt isn't quick enough to catch that surge, of course, so had never shown it.
I knew motor inrush could be pretty substantial (I work with 460V 3-phase stuff for a living) but had always heard 3x running, or maybe as high as 6x running.  2kW, though, for a fridge...  Wow!
I hadn't thought about the equalizing voltage yet.  Up to now I've only used SLAs, so it hasn't been an issue.  I may just turn off / disconnect everything during equalization, or switch over to the PSU.  The MFJ conditioner is another good idea, been thinking about getting one of those anyway for portable use.
Re: How to decide on a system voltage? (3.00 / 0) (#12)
by Jeff (ruralmcguyver at yahoo dot com) on Sun Aug 10th, 2008 at 11:18:13 AM MST
I have a 1200watt/3200peak MSW inverter & it starts my fridge with no problems. I have found a couple decent kits that will reduce the startup problems for those that need it. They might even decrease the load on the batteries enough that it saves some power.
http://www.azpartsmaster.com/Products/Compressor-Hard-Start-Capacitor---SUPCO-RSC10_SPP10.aspx
http://www.filterace.com/detail.aspx?ID=1112
Rural McG
How to decide on a system voltage? | 14 comments (14 topical, 0 editorial)
