Ah yes, after I posted I was doing a little more figuring and realized I need to throw in the inefficiency numbers. I'll have to revise my figures a bit there.
The fridge is a pretty good unit, I think. It's only 5 years old, and I could probably make it even more efficient if I'd get around to filling it up! I'm single, and there's not much in there... I do drink a lot of water, so have thought about buying a bunch of water jugs to take up the space and help hold the cold. (Then I just have to remember to keep them filled!)
I've done quite a few of the usual conservation measures. CFLs everywhere, the house was already well insulated, programmable tstat to set back the A/C during the day (usually never runs when I'm at work), things like that.
I'm not terribly keen on grid-tie for a couple of reasons, first is that my utility company doesn't give that great of a deal on it - the very best I could do is reduce my electricity charge portion of the bill to zero (would still have the usual fees), I can't actually make money on them! Considering my monthly bills average in the $70-75 range, we aren't talking much savings. There are also no installation subsidies, according to findsolar.com the only thing I could get is the federal rebate.
Also, a major motivation here is backup power - while extended outages are still relatively rare, they are becoming more frequent. Worse, the two extended outages that have affected me were both mid-winter during ice storms (also getting worse in recent years in my area) which is a miserable time to have no power. If I put in an RE system, I darn sure want to be able to use it in an outage! I understand it's possible to have batteries on a grid-tie, but it does seem to be the exception rather than the rule.
Is the derating of the solar panels really that bad?!? I know I've been seriously unimpressed with the "45 watt" panels I got from Harbor Freight, but just figured that was more due to the usual HF quality than anything else. (Best I get is usually 25W.) I remember reading that there is some derating due to the difference between "test conditions" and "real", and there's also the loss due to voltage mismatch - for which I intend to use an MPPT controller.
