A PV question | 4 comments (4 topical, 0 editorial)
Re: A PV question (3.00 / 0) (#4)
by Ungrounded Lightning Rod on Thu Sep 11th, 2008 at 09:52:44 PM MST
Leaving the panel driving a load results in less heating of the panel than either opening or shorting it.  The power that would drive a load heats the panel instead in either of the don't-drive cases.
Since the power to the load is about 15% or so of the total sunpower absorbed by the panel - and all the rest heats it, too - it doesn't make a lot of difference.
So since you've already got a dump load hooked up I'd say leave the panel driving the load and let it run slightly cooler.
