Forklift Battery packs ?? | 5 comments (5 topical, editorial)
Re: Forklift Battery packs ?? (3.00 / 0) (#1)
by richhagen (richhagen (a t) Juno.com) on Fri Sep 12th, 2008 at 01:45:03 PM MST
If it were me, I would snap them up.  There is probably a bit of life left if you take the best cells to make your 48V pack.  Forklift batteries are usually high antimony alloyed plates and generally tolerate quite a bit more abuse than most batteries.  On the downside, their self discharge rates are generally higher.  A warehouse where I have done some work has some battery powered lifts which recieve regular abuse on a timed overcharge and then run flat, and they just keep chugging along.  Just because they are not holding enough capacity to power the forklift for a whole shift does not mean that you won't get several years of life out of them as re batteries.  I am not a battery expert, but I would not hesitate to grab those.  Rich
Forklift Battery packs ?? | 5 comments (5 topical, 0 editorial)
