Wind Energy AIDED Car again. | 9 comments (9 topical, editorial)
Re: Wind Energy AIDED Car again. (3.00 / 0) (#1)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Fri Sep 12th, 2008 at 03:30:42 PM MST
If you are going to put sails on the car and sail it then you need a big parking lot
If you are going to put a wind turbine on a car to make it go farther then see the accurate answer that is available in your first posting.
W o o f -={(
Re: Wind Energy AIDED Car again. (3.00 / 0) (#2)
by Ungrounded Lightning Rod on Fri Sep 12th, 2008 at 03:40:37 PM MST
A wind turbine pointed sideways, and at many other angles. could potentially help (though a sail would be better).
A wind turbine pointed straight forward, or close to that, is an overunity device..
Wind Energy AIDED Car again. | 9 comments (9 topical, 0 editorial)
