Critiquing PVC Props | 22 comments (22 topical, 0 editorial)
Re: Critiquing PVC Props (3.00 / 0) (#5)
by ghurd on Sat Sep 13th, 2008 at 05:35:07 PM MST
There is not a lot to go on with PVC blades.  "Try it and see" is what I do.
The PVC blades I make come down to a guess on the first set.
The 2nd set is a guess at fixing the problems the 1st set had.
The 3rd and 4th sets are trys at getting a little better.
Longer/shorter and/or wider/thinner.
The smaller ones look OK.  Root may be a little wide.
I don't like the big ones.
The huge root looks like it will just cause drag.
Plus I think 4' is about the limit on PVC.  Loaded, in a strong wind, they bend back more than most people would expect.  It would not surprise me if the 5.5'-er hit the tower.
Most reports show PVC blades will break.  Maybe not today, but it will happen.
That's a big chunk to go off at high speed.
Might find a 4' that is a little wider than the 1st 4' set will drive the treadmill motor OK.  I believe PVC can somewhat 'drag past stall'.
Might make a decent low wind machine, with less danger.
On the bright side, the trailing edge is in the right place.  :-)
